Not if you want to use the negative heater scheme...Interesting, good enough for a U67 style mic?
No, the U67 needs a negative filament voltage. (The grid bias is derived from this voltage).Interesting, good enough for a U67 style mic?
That's a pity...The outputs have a common ground and both outputs are positive referred to ground.
Yes, if someone with your skills designs a solution, it will be really good. The question is, beyond efficiency, is it necessary? Is the old solution really significantly worse in terms of sound?I’ve used step-down converter for H+ of my V76 mic pre. Not a ready-made module, but designed around some switcher chip (don’t remember the number off the top of my head).
Input and output were filtered (CM and DM chokes on the input and LC at the output). It was also designed to run in CCM, and switching frequency was around 100k.
No traces of noise whatsoever. And very efficient compared to LM317.
Ruud, how much current can you draw from the B+ and F+ rails? Link?I have used a Chinese DC/DC converter (output 6.3 V and 150-280 V) for a tube microphone without any problems.
I’m not Ruud but specs are:Ruud, how much current can you draw from the B+ and F+ rails? Link?
Actually, the solution is not that difficult. You can find another variation in Merlin Blencowes tube preamps design book. The components used are all through hole and easy to get. The circuit may even be available at Merlin’s site.Yes, if someone with your skills designs a solution, it will be really good. The question is, beyond efficiency, is it necessary? Is the old solution really significantly worse in terms of sound?
I'm not a professional gear producer, I'm a hobbyist. For me, tried and tested DIY solutions definitely have advantages. It's also about what I can realise myself at home.
There can be different perspectives on this topic, and now you know mine.![]()
Indeed, there is a solution for every problemI have used a Chinese DC/DC converter (output 6.3 V and 150-280 V) for a tube microphone without any problems.
Out of curiosity, have you tested this DC/DC converter with a simple 9-12v wall wart?I have used a Chinese DC/DC converter (output 6.3 V and 150-280 V) for a tube microphone without any problems.
I wouldn't try this unless you have another source for earth ground.Out of curiosity, have you tested this DC/DC converter with a simple 9-12v wall wart?
It could be a super compact solution to power a tube mic.
thanks
