While looking at the schematics for the Mackie Onyx 1220 mixer, I noticed they implemented a line input with +/-20db trim using only two opamps stages.
Technically speaking, they used a fixed gain balanced input, followed by an active gain/attenuation adjustment stage that looks a like an Equaliser without frequency dependent element.
This circuit creates a noise penalty twice.Especially the gain adjustment circuit in effect first attenuates the signal by around 10dB before boosting the now much more noisy signal back to nominal (0dB gain setting).
I'm wondering how this approach compares to the praised Douglas Self line input proposed on his book.
I am not sure who "praises" Mr. Self and for what exactly.
The Mackie looks more useful since unity gain should be at center of the pot, and there is more gain range. but what is the tradeoff compared to the Self approach (below)?
I personally do not consider either design particularly good. The "Mackie" carries a large noise penalty, the "Self" severely limits adjustment range.
Mr Self has a few better options in his book.
If we need gain trim, the "double inverted" circuit is better, in my view.
Something like this in my view beats of the others all around. Using a log pot you get ~ -6dB gain at around centerpoint. Lowering gain lowers noise from an already low baseline.
As all Op-Amp's operate inverting we have a noise penalty, but next to resistor noise it's not that relevant. On the positive side, any common-mode distortion doesn't happen.
Also, if we have another inversion in the full system (say tone control or mix amp etc.) we can flip input polarity and have a very simple SE input, or even more important a high impedance (1M) Instrument input using a nice J-Fet follower ahead of a resistor into mix input.
As long as the jack has a switch that shorts the Jack Tip to ground when not plugged in the impact on noise is nominal. If not, extra switching is needed. A Mic-Input can be added using the classic "British Mic-Pre" frontend (e.g. Elliott Sound Project 66). Using a coarse gain switch in (say) 12dB steps can be added, fine adjustment with gain trim. Voila, simple universal input for a mixer or similar.
On the other hand, if a balanced out is needed (say to feed a AD input), the Birt Circuit is preferable, though gain adjustment becomes more complex.
A High-Z input for this can be made from a J-Fet operates as phase splitter. A Mic-Input can be added again using the classic "British Mic-Pre" frontend (e.g. Elliott Sound Project 66). And we have a very simple and high performance Mic/Line/Inst Input to ADC circuit .
Thor
