That’s a drawing I received with some 4060’s having no connector attached. The bit on the right is my addition for a 9V battery box I built. None of that is in the mic, it’s completely out of context. Going quiet is a well known end of life symptom with 4060’s.Hello,
i have a DPA 4060 that works but has a much lower output than another. I thought it could be a bad solder or broken wire at the XLR but rewiring didn't change anything. Could it be that the 2.2uF 50V capacitors need to be changed?
