DPA 4060
ubxf
los angeles
Hello,
i have a DPA 4060 that works but has a much lower output than another. I thought it could be a bad solder or broken wire at the XLR but rewiring didn't change anything. Could it be that the 2.2uF 50V capacitors need to be changed?
Because of what? Leakage? I don't see that being enough to drag the voltage down that much. Can you measure the voltage at the electret? It's such a simple circuit I would have to wonder if maybe the electret is damaged.
Hello,
That’s a drawing I received with some 4060’s having no connector attached. The bit on the right is my addition for a 9V battery box I built. None of that is in the mic, it’s completely out of context. Going quiet is a well known end of life symptom with 4060’s.
Thanks Doug, i re-posted your schematic because it is exactly the pcb that is in the xlr plug in my mic. I worked on the mic some more and it looks like it is not going to come back to life.
such a few count of components that you can even change them all.
If that doesn't fix it then Bo Deadly might be right in that it could be a capsule failure.
Maybe DPA have spare parts and you could order a capsule element,
or send the mic to them to be fixed
