replaceablehead
New member
- Joined
- Nov 24, 2023
- Messages
- 3
I did something very stupid yesterday. I've got quite a bit of rack gear of varying power requirements and while I was upside down behind by mixing desk plugging a few things in after moving house I went and plugged my 100v Drawmer gate into 240v. In my defense, the unit is labeled 100v/230v and it had been so long since I'd plugged it in that I'd quite forgotten that it was one I had bought from Japan. Suffice it to say it blew the fuse, but after swapping that out and plugging it into the right step-down transformer the unit seemed to be operational.
Anyway, today I've chained it up with my reverb and I was playing drums through it when I noticed it fizz for a few seconds and then sort of fade out. I went over and twiddled with the threshhold a bit and the sound abruptly returned I resumed drumming for a few minutes and it happened again. This time knob twiddling didn't work, but power cycling it did. I played for a few more seconds and it cut out again. I noticed that by power cycling I could get it to work again by only for about 20 seconds or so. I left the unit on while I had a think about what could be blown and then I tried power cycling it again which no longer worked.
The light meters on both channels work and show when the signal is passing and when the gate is closing, it's just no sound comes out when the gate opens. I'm just a little surprised because I thought if it was overvoltage it would have just blown the capacitors in the power supply or the transformer and it wouldn't turn on. I don't know much about circuits though to be honest and this is the first time I have every plugged something into the wrong power supply, I'm normally very careful.
The next step is to open it up, but any ideas on what I should check first?
