I've just finished building this, and although it's up and running, passing audioand compressing, there are a few voltage anomalies I need some advice on, if possible. I've gotten the voltage test figures from the drip PCB and also the LA2A-deconstructed.jpg posted earlier on this site:
Running from the transformer output (hammond 240V):
Red leads from secondary 274VAC each; Greens 3.3VAC
Test point at PS caps (275V) - 250V
Test point at R1 (240V) - 207V
Test point at C2 (131V) - 111V
Test point below 12AX7-2 (110V) - 90V
Test point at R12 (1.2V) - 1.03V
Test point at R35 (136V) - 116V
Test point at R36 (9V) - 8.2V
R9, at 12AX7-2 should be (205V, 115V) - 195V, 106V
R34 should be 275V, 135V - 249V, 88V
I'm running a tube rectifier. The NE2 bulb is also flickering, not on-off but lower-higher.
I have a Hairball VU meter, which wants 3.6 to 5.2V. I've connected the 6.5V taps, and it is glowing a dull orange colour.
Is the voltage drop at the PS caps significant? Would this account for the lower voltages throughout?
Any help would be greatly appreciated.
Many thanks
Stephen
Many thanks
Stephen
