Hey folks. Long time lurker, first time poster.
I'm having some pretty intense bass roll-off on my Drip Opto 6. I've tried turning the stereo adjust and the limiter response screws, to no significant effect. I've confirmed the C1 through C4 capacitor values are correct. I've checked everything with the gain reduction set at 0 and also with it raised. I've removed the T4b's. All with no significant change.
I've noticed the problem when going...
Mic --> Preamp --> LA2A; also when going
Dynamic Mic --> LA-2A (no pre); and also when reamping pink noise by going
EMU 1212M --> LA-2A. So I'm pretty sure it's the LA-2A at this point.
Here's what I get with the pink noise generator. The first Freq Spectrum is the pink noise, the second is with the LA-2A.
As you can see, I basically have nothing below 200 Hz. There's also a bit more HF content. I even notice that when recording spoken voice, that you can hear and see additional HF content above 2K or so. Sooo... any thoughts on this?
As you can see, I've searched, I've read. I've followed up on the most common suggestions, but I'm still a bit stuck.
