I love the amp that I have and I want to get every drop from it before I have to consider buying a new one.
Why would you ever want to replace this? I have PA amps from 1978 still in service. Dave probably has older ones around. 600 Watts sure should be enough power. Gosh, I remember when 100 watts was "big" and the 300W SVT was a jeans-creamer. I only ever met one, and only ever knew of one person with two SVTs. Now you can get that power in 10 pounds????
It would be nice to mention what a "Stewart World 600" is; mono? stereo? bass-head? general-purpose PA amp?
Ah:
specsheet
FTC Power Rating: 110W x 2 @ 8 Ohms 190W x 2 @ 4 Ohms
FTC Power Rating: (bridged mono): 400W x 1 @ 8 Ohms, 600W x 1 @ 4 Ohms
Frankly, if 2x110W=220W is "not enuff", then 600W is not going to be enough "more" to make a difference.
I also feel that you have Vette power on Yugo tires: a few Twelves isn't going to handle much of a 600 Watt power capacity.
But if you think Twelves and Sixes are "bass cabs", then you must not be a heavy-metal bass-thrasher, more a light-fingered jazz stylist. (Or else you are in trouble.) So maybe this is enough speaker for your needs. I still think this is too much power. I've seen a 2-stack of B*se 901s (16 Fours) sound lovely on a 150W amp, and a few months later the bassist said it sounded wrong and I found ALL the cones SHREDDED. Twelves are bigger, but you just have two (or three counting the quad-Sixes): your total cone area is only 150% of the two-901s, and you are talking four times the power? You better have the LIGHT touch and tough speakers, and pray for zero "accidents".
putting 2 6.5's and a 12 on each channel
That would not be my first jump. I'd suspect the Sixes need different gain than the Twelves; maybe different EQ. And it does not really solve your impedance dilemma.
I'd wire the four Sixes series-parallel, 8 ohms, and let them have one side of 110 Watts. That's 27W each, on a 45W rating. The alternative, just-parallel, leads to around 100 watts in each 45W speaker. IMHO, for stage-amp, that's just asking for trouble.
The Twelves are tough. How did you end up with 6 ohm speakers? Are these Lead Guitar, MI Bass, or HiFi speakers? Makes a big difference in efficiency, bass cutoff, and ruggedness. 90W in Guitar speakers, ala Fender Twin, can make one heck of a racket. 300W in some 12" home subwoofers will give a dull thud, ample in a living room but not in a club.
The bridged-mono rating
seems to imply that each side could drive 2 ohms at 300 watts. But they don't actually say that. In fact it says "600W" only on the front page: on the fine-print page, it only goes up to 400W (8Ω mono bridge). The heatsinking looks just-enough for reliable 2x200W operation. It might survive 600W for days; if you love it, do you want to run it maxed-out and hot?
True, one Twelve (6Ω) and two series Sixes (8Ω+8Ω= 16Ω) is 4.3Ω, on-spec for the 2x190W rating. Each Six gets 24W, 48W total; each Twelve gets 126W. Total electrical power, 350W, which is "same-as" the fine-print 400W rating, and just 2.3dB less than the big-print 600W rating. But will two Sixes, 48W total, "match up with" one Twelve eating 126W?
