flaheu
I've stuffed a dual JLm99 board with 5534 and OEP 1+1:6.45:6.45 input transfo and i would like to understand the jumper config fot the ration og this transformer, see the link to the photo:http://lacave.myphotoalbum.com/view_album.php?set_albumName=album01
Is the red jumper the 1:6.45 and the yellow the 1:13 ? If i move the jumper between these 2 positions I can hear a level difference but when i use the impedance pot (27K + 100k pot) on both config the difference is not so obvious.
If I put a switch to flip between 1:6.45 and 1:13 I can also switch to another value for RL -> xx k + xx pot with a DPDT ? What would be the value for the 1:13 ? I can not find any value in the table for th Jlm BA :http://www.jlmaudio.com/Baby_Animal_Mic_Pre.htm
Also, is that normal if when i turn the impedance pot the sound gets more bass but the level diminishes ?
Thanx
By the way, this preamp has loads of gian :shock: :shock: :shock:
Thanx to Joe :thumb: :thumb: :thumb:
Thanx
