Dual rail PSU
beatnik
Italy
I am making a linear power supply with two outputs, see attached schematic
top part is 32V for audio circuit
bottom part 12V for relays and LEDs
I am trying to make this from a single 12V AC transformer
I have noticed that when the 12V section is connected there is an increase in hum on the audio circuitry powered by the 32V rail
If I remove R7 the noise drops considerably.
Do you have any suggestions ? Perhaps the rectification of the 12V section needs changing ?
    19.8 KB
My guess is IC1 doesn't have enough dropout when the 12V rail is sourcing current (dragging down the 12VAC slightly).
What is the voltage at the top of C9, and V2+, both with and without R7 populated?
The margin is tight but I don't think this is the cause of the problem
There is 35.4V at the input and 32.2V at the output of the regulator
It makes no difference whether R7 is in or out of the circuit, however the noise further increases when the load is connected to the 12V rail
To give you an idea, the noise level without R7 is -74dBu, with R7 in circuit but no load it's -66dBu, with load -56dB
Throughout these variations the input to IC1 remains constant at 35.5V and the output at 32.2V
I have also tried the 12V rail without LM317 section and leaving it unregulated but the same problem occurs
Could the problem be caused by an interaction between the rectification of the 12V rail and the voltage tripler for the 32V rail ?
It's drawn strangely to me, now that I look closer.
For example: you've declared AC2 as the common line for both supplies, so I don't see how it's possible for D9 to ever turn on, once C10 charges.
A common problem in power supply design is dealing with reference ground integrity. PCB traces have finite resistance so current flowing in those traces will cause voltage drops that can corrupt clean references.
It helps to visualize PCB traces as resistors so the voltage drops are easier to conceptualize.
A common area of problems is around reservoir capacitor grounds.
It's typical to see a bridge rectifier for the 'bottom' supply: see this (which is a doubler version, so would need a third stage added for a tripler):
dualsupp2-png.769042
I have tried the solution you proposed with the bridge rectifier but I get basically the same problem, there is a 10db difference in noise with the 12V supply line connected.
What kind of regulator? Unless the regulator is specifically a low-dropout design it is probably not actually regulating with only 3V drop across the regulator.
LM317 I believe these have a minimum 3V input to output differential ?
When the 12V rail is connected the voltage before the regulator decreases only 0.2V, and the output voltage remains stable at 32.2V
I have tried adding a multiplier stage, so now there is 48V on the input of the LM317. No difference
Just another thought, since I am using a 12V transformer with dual secondaries connected in parallel, I'm wondering if I should try using one secondary for each rail, instead of powering both rail from the same two windings in parallel ?
How are you measuring that voltage? Would you instrument show the level of variation of that voltage? What I am trying to get at is that a DC voltmeter will likely not allow you to determine if the voltage is actually constant or not. An AC voltmeter may, but what you really want is an oscilloscope to probe power supply circuits.
Right, I get what you mean, but with 48V on the input and 32V on the output the LM317 should have enough margin.
Observing the 32V rail with the oscilloscope (probe on 10x and short grounding) doesn't show anything alarming.
The 32V rail is stable with no signs of noise, however the noise is injected on the audio lines.
I have tried powering LEDs and relays with an external 12V power supply and I don't get the same issue
There must be a problem with how the rectification of the 12V rail and doubler / tripler for the 32V rail are interfering with each other.
Looks like I have found the culprit, it seems that the issue is because the 0V of the two rails are tied together, if I keep the 0V of the 12V rail floating the noise doesn't get worse.
I could not do that on the original PCB because the two rail shared the same ground plane so I have built the 12V section on a separate PCB
As I warned the other day clean ground (0V) references are an issue in PS design.
3 terminal regulators output voltage is relative to the ground terminal voltage so AC noise on that ground pin will get superimposed on the output voltage.
Write your reply...
