Potato Cakes
Hello, Everyone,
I wanted to share my latest build. It's a variation of a Champ with modifications that are attributed to the legendary amp builder Dumble. I added the extra challenge of cramming all of this into a Vibro Champ chassis, which was almost too small. I added a couple of things like selectable grid stopper resistors to V1a/b (56k and 22k), a switch to send the first input to both halves of V1, line level output, selectable negative feedback, and effects loop. I started out being meticulous with the wire routing but during the troubleshooting process my neat-ish work began to unravel. I also made the back panel to accommodate a number of features like selectable impedance, but I wound up abandoning trying to include every option possible on a small amplifier and the result was unused drill holes. I also opted to use a full wave diode rectifier instead of a tube as there wasn't enough real estate to safely fit another octal tube socket's foot print and wiring.
All that is left is to wrap the head cabinet in Tolex.
Paul
Paul
