Dumble inspired Fender Champ build
Well, I couldn't leave well enough alone. I wound up finding another similar circuit build that had the same tube compliment and layout that I was using. I pulled out the old board and started over. Along the way I may or may not have discovered a number of issues that caused me to like the amp at first then slowly not like it as much. There is only so much a project and take a bunch of resoldering before you start to create additional circuit errors. Regardless, the newer circuit has a lead channel mod which was something that I was trying to incorporate to a degree in the first place. I also made the Extra Sprinkles function as a High/Low input switch. The Master Defeat switch has been repurposed to taking the tone knob out of circuit.
I didn't get a chance to test it tonight as I spent a bunch of time chasing down a problem with the B+1 voltage leaking to the cathode on one of the 6V6GT's, which caused the power output tube cathode bypass to explode. Somehow, there was about 220 ohms of resistance between Pin 3 (plate) and pin 8 (cathode). When I pulled the tube, it went away. I put the other tube in the problem returned. The pins on the tube socket are not adjacent which ruled out the rare possibility the socket had a failure with pins making a connection inside the moulding. I could not find any stray short or other issue so I started pulling components off of the socket and then the problem went way. I put everything back in place and the problem was still gone. I generally don't like it when problems solve themselves, but as long as I don't do anymore work on this circuit I think it will be good. I did a quick test and it's very quiet and the tone knob now seems to function as one would expect. It also seems to has much output as I would expect a 15W amp to be able to deliver. I'll mess around with it tomorrow and report back. So now, this project has been completed. Seriously this time...
Paul
    2.9 MB
    1.2 MB
When I noticed the title I was expecting a SE output amp. Are there any SE (or DSE) Dumbles out there?
There was a fairly simple homebrew D inspired circuit, by a guy called Mat on The Amp Garage site about 13 years ago. It was called 86 Special.
Reduced D front end into a simple SE power amp.
12ax7 » ef86 » el84.
I rolled a similar one with a 6sl7 front end out of curiosity. Still have it somewhere, I recall it worked great with 50s ∫ 60s P90 guitars like Gibson or Mosrite giving a unique growl. But You have to like the SE overdriven sound. It seemed a bit one–dimensional to me. I found more response in an old 50s GA40, which kind of puts a perspective on it.
