Eagle library for Edcor PCW transformers
McCroskey42
San Diego, CA
Has anyone done an Eagle library for the Edcor PCW series that they'd be willing to share? I did a search for "eagle edcor" and turned up nothing.
volker said:
I recommend you thoroughly test before ordering a pcb ;).
Footprints look great! Have you ordered any PCB's with these? Im not sure hot to test the pin/pads to make sure they are right short of making a small design.  ;D
No I have not, hence my suggestion. I would do two things: print out and check with a real unit that it is properly scaled. And check that the pins connect where they belong according to the datasheet, are symbol in the schematic and model in the layout coherent.
I don't expect anything to be wrong (never know of course...), it was just a heads up to let you know I haven't tested it yet.
