It's when i do a design rule check. I've got it quasi figured out. I think what's happening is that it thinks that traces are too close to text I've added on the dimension layer (same layer as the silk screening) and the outline of the board.
Should the outline and additional text be on the dimension layer? How do I get eagle to understand that it's of no consequence?
Any idea how to get the drc to ignore the dimension layer? I noticed that when I flood the ground plane, it thinks that it needs to avoid the board outline.
