The 1176 is so common here all you need to do is get the PCB, a Par-Metal chassis and find the parts list for everything else. I'm sure there are several complete parts lists floating around here. You should be able to order 99% of the parts after a few searches here. (Check the META) the only tricky parts may be the meter, the ratio switch, and the transformers, simply because there are several options.
