Id like to use either a Edcor XSM https://www.edcorusa.com/xsmseries or PCW https://www.edcorusa.com/pcwseries as a 1:2 step up output transformer.
Since Edcor doesn't advertise any as being 150:600, and since I'd like to drive the primary unbalanced/single ended with ground as reference, I'm wondering whether I'd be better off using a 600/150 backwards, or if I'd be better off using a 600/600 while only driving the input(+) and the (grounded) C.T.?
And if the second option is the case, should I then leave the input(-) unconnected, or would I be better off grounding it together with the C.T.?
Basically, I'm searching for a 150/600 trafo. Either a 600/150 backwards or using only one half of the primary of a 600/600. Which do you think would be the best solution?
