ELA M251 C3 - anode to OT-coupling cap?
rock soderstrom
Tour de France
Berlin
Hi guys, I have two different info's regarding the output coupling capacitor in the Telefunken ELA M250/251. The schematic dated 2. January 1961 says 1uF, the schematic dated 14. February 1961 says 3.2uF. The related C12 with the same tube and OT (Haufe T14/1) has a only 0.5 or 1uF capacitor at this position.
What would you use? I am aware of the technical consequences of the different values, the lower corner frequency shifts accordingly in a range in which I do not hear any differences anyway.
The only thing that makes me think is the saturation of the OT.
elam250_2.jpgScreenshot 2023-07-19 at 00-35-00 ELAM250E W_ ELAM251E Schematic - Telefunken-1534_2.pdf.png
Wow, is that the frequency response from an original ELA M251 or the American replica?
I actually heard an original M251 this week as I am researching this type of microphone. The low frequency response was excellent and not nearly as described in the frequency write-up above. The lower -3 dB point here is just below 100Hz! Unbelievable!
But maybe it's really like that and again a proof that we normally record relatively little meaningful below 100Hz.
To the original question, I'm still wondering why the designers at that time after a month tripled the original value of C3 to the first schematic? A drawing error?
I think 1uF is sufficient.
View attachment 111959View attachment 111960
Also when you go for lower cap values, depending on transformer characteristics, there could be a resonance at cut-off point causing a quite nice bump before the attenuation.
Yes, this is something to consider, since the C interacts with the L. I will see when the transformer arrives how this behaves. Maybe some kind of built in Pultec trick. 😅
How important is the value of the output coupling capacitor, in a microphone that attenuates almost everything below 100 Hz?
That response graph from RecordingHacks is ridiculous. A microphone with that response would barely be useful for vocal work, let alone anything else.
Here is the chart from the original M251 manual from Telefunken. (Which I found, ironically enough, on RecordingHacks.com!)
As you can see there is a moderate tilt in response between 100Hz and 500Hz; below 100Hz a gentle rolloff to -6dB @ 40Hz. From there we can extrapolate -12dB @ ~20Hz. Still a little steep among it’s peers, but broadly in line with what you might expect from a 30M grid resistor.
    745.8 KB
this has been posted about at this forum.
Zebra 50 had a good post years ago about a Gefell microphone IIRC.
I tune the value by ear or measuring.
As suggested above, if you tinker with a smaller output cap you might create a pleasing lift in the 100Hz range that brings it closer to a C12.
Maybe I'm wrong, but if you use a capacitor of 1 microfarad, then in relation to the inductance of 160H of the winding of the output transformer, 12 Hz is obtained.
If 3.2 microfarads, then this is 7 Hz.
How can there be a "hump" in the region of 100 Hz from such frequencies?
Apologies, I deleted my last post by accident. I have conflicting information on T14/1 from the Haufe data sheet and from AMI.
One of these must be wrong. I can’t imagine anything the small physical size of the T14/1 providing 160H, but I’m open to correction.
    83.3 KB
    135.2 KB
