My old PL-10 is due for a foam replacement. EV doesn’t sell the foam kits for it anymore. I was thinking about getting a windscreen for a shotgun mic of the appropriate diameter and cutting it lengthwise to size for the main foam “sock” that the capsule chamber fits into, then cutting a disc of the big open cell foam of the type that the RE-20 uses in front of the capsule for the same purpose on the PL-10. I’ve found both a windscreen that has the right inner diameter for the capsule chamber and big open cell foam of the right thickness to cut the end disc.
But before I go down this path, does anyone have a better option they’ve used? I’ve heard of guys using an RE-20 replacement kit and cutting/re-gluing the sock to fit. But that sounds like more trouble that it’s worth and besides it will leave a hard line of glue down one side of the sock.
