Minion
Hi Folks, I am very new to electronics and am basicly try to teach myself by doing reading and research on the net and of cource posting questions on message Boards like this one.. :grin:
Well I just bought 8 Transformers on ebay for $5 that I was thinking of useing to build power supplies...The Problem is that since I know nothing about Transformers (Accept what they do) I don"t have a Clue as to how to wire it up or even which wires are which....
The Transformer is supposed to be a 110v to 26v or a 220v to 26v Transformer and has these Markings on it:
26v OV 26v
T-201-1
OV 120V 220v
It has a red, black & Brown wire comeing out one side and a white, yellow & blue wire comeing out the other side....
I assume that one wire on one side is for 110v operation and the other is for 220v operation and the third wire is maybe the negitive lead for both/either voltage??
And I also assume then that on the other side one wire is for 26v from 110v and the other is 26v from 220v and the Third wire is the Negitive lead for both/either voltage??
Here is a Picture of the Transformer:
So could someone tell me which wires do i use for 110v to 26v??
I was also wondering if I connected up the 220v to 26v but ran it on 110v would I get 13v?? and If I can do this is there also a way that I can run both 26v and 13v at the same time??
I was also wondering If I can safely use a 15v Voltage regulator to get the 26v down to 15v if I put a Heatsink on the regulator??
I think that is about all the questions I have in this area at this Time but I"m sure I will have many more in the Future....
ThanX a Lot !!! You Guys/Galls are Great!!
26v OV 26v
T-201-1
OV 120V 220v
![Trans.jpg](https://proxy.imagearchive.com/4a9/4a9c1a7131d9096380f1fac2af7daffc.jpg)
