thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
I have an input transformer with 3 separate primaries. In order to get 3 different gain / impedance settings, there are combinations that can be used whereby you alternate between using a single tap, taps in series or taps in parallel.
Obviously, I can do this in a multitude of ways…
Conventional switches can suffer from stray capacitance, not to mention that you need contacts suitable for switching low-level signals (this is a high-gain application). Relays could do it, but that’s getting complicated as they’ll want a dedicated power rail. A Shallco would be great, but that’s uber-expensive for a stereo unit. Gold-plated jumpers will work well and they’re cheap – the downside will be that you’ll have to take off the lid to change tap and it’s not exactly studio-friendly if you intend to let other people use the device. I guess I could do it via an external tag strip?
What’s the most elegant way you’ve seen an OEM do it?
As per usual, I’m probably blind to an obvious, elegant solution…thanks in advance.
Justin
Justin
