The EMI RS144 was the little 4 input passive pre-mixer used at Abbey Road studios back in the days of the Beatles. "Recording The Beatles" notes that users were warned about interaction between controls because the design had aimed for minimum insertion loss. Users were told to ensure unused inputs were set to zero. With only one input used and the other three set to zero, the loss was only 6dB.
So, I am just trying to work out how they did this as I cannot find a schematic. They used regular Painton faders so these were no doubt bridged T types, So, assuming all the inputs were balanced and more importantly floating, the design could have been little more than four bridged T attenuators wired together much as in the attached schematic from the Audio Cyclopaedia:
Ignore the transformers and the output gain control. I am not quite sure why the output is taken from the middle and bottom of the network, nor why the bottom cold is connected to ground.
The second issue is, if I wanted to replicate it, how to make a reasonably good bridged T attenuator with just a dual ganged pot? It is easy calculate the resistor values required:
But can it sensibly be done with a dual gang pot?
