So this just came in for power supply recapping and general service. The first and most obvious problem to me is that everything is upside down, even the back.
Now I thought about it long and hard - perhaps I could machine a new faceplate which faced right side up... etc. But as we wanted to keep as much of it original vintage as possible here is what I plan on trying... carefully.
I am first going to remove everything from the faceplate and carefully set that aside. Then I can remove everything from the back of the unit desolder all the connections, remove the back plate, and then take all of the components out of the chassis. I will mark each component as to which side was up that should down and hopefully I can reorient them all during reassembly. I am just going to use a magic marker on the power cord with some white gaff to make which is up or down. I don't want to have to make a new vintage cord; that really takes some patience.
At that point, I can flip the chassis 180 degrees to the earths surface, and begin carefully reassembling the unit right side up. If I put I all back correctly, it should be right side up when we are done.
I really hope this one come out, the last one came out all sideways.
-Tony
PS: I was going to save this until April 1st... but what the heck.
-Tony
