Deepdark
Hi all. I need help with my turret build of a Pultec EQP1A. It has been done with cinemag transformers. Main issue is with the output transformer.
When I power up the unit, it make a kind of vibration sound, very loud, like if there was two metal plates vibrating on each other. I checked all voltages and they looks ok, exepted 2, which are a little low, according to the schematic, I retrace all wire and everything looks good, all resistors values looks good, too. I used the linked modified schematic I received, which is made to accommodate the Cinemag CM9600. I'm a little at a loss with that issue, i dont know what can cause the transformer to make such a noise and I'm afraid the trouble is behond my knowledge.
I tried it on my computer to hear what appened. I sended a white noise through it and back to my interface and it's all noise. No matter what i tweak in the eq sections, it seems to not work. Maybe it works and the noise cover it all, i dont no. I dont have Any scope to Check it. If you could provide some help i would be gratefull.
You can check the linked layout with the voltages in blue (schematic values) and in red (my values). My understand is that the trouble sits around the 12AX7 section. But I can't sorting out the noise coming from the output transformer. I noticed that when I touched the turret mark with a star on the layout, the noise coming from the OPT attenuated a little. What could that means?
Thank you
Thank you
