European capsule suppliers?
TheFibs
Member
Belgium
Hey all! I was looking at the Transound capsules from this project: True Condenser OPA Mics. However, the listed supplier JLI electronics has absurd shipping fees to Europe, so I was wondering if there are any European capsule suppliers that you guys know and use.
Thanks in advance,
Tom
Hey! Thanks for the reply! I had a look at their store but it looks like they only have the electret capsules from JLI, not the true condenser ones like the tsc-1 and tsc-2.
Tsc 1 and tsc 2 are actually Takstar manufactured capsules. I don't know if you are in hurry but you can contact them directly.
I think the TSC-1 and TSC-2 are just re-badged 'standard' K.67 Chinese clones...
So you should be able to find those for less money elsewhere .
Like here for example: https://www.aliexpress.com/item/1005004608418122.html
Personally, I prefer to use the edge terminated 'K.67' style capsules -- like this one for example: https://www.aliexpress.com/item/1005003678385151.html
EDIT: I see that kingkorg has been able to identify the exact type..... How different those are standard K.67 Chinese clones, I wouldn't know?....
Oh, thats interesting. The guy from the instructables was saying they were made by Transound, which doesn't sell to privates. I'm not in a hurry so I could definitely contact them directly.
Whats your experience with those? I heard aliexpress can be a bit of a hit or miss.
I've always been lucky with my Aliexpress purchases, although I have heard it doesn't always go well for some folk.
Worst thing is the long delivery times - although you can sometimes speed those up by paying a little more for alternative shipping.
Buying cheaper Chinese LDC mic capsules is always a bit of a lottery. As I say, I've been quite pleased with the edge terminated ones I linked to above.
Taking a look at your avatar, you might like to have a listen to a extract of a recording I made? -- uses those capsules for vocals and guitar...
https://tinyurl.com/DSOTM-ext
It's only a bit of fun .. just a couple of pensioners making amateur recordings in the spare room! :)
Nice arrangement of what is probably my all time favourite piece of music! And great vocals too! Were the drums recorded or are they digital? I'm thinking digital but not quite sure.
Brilliant work nonetheless!
You're just being kind! :)
Yes, the drums are digital -- in fact it all is - apart from the vocals and guitar...... Made on Reaper with a Yamaha MOX and YC61.
Mics are RF mics made from these notes: DIY RF Condenser Microphone ... using, as I say, the edge terminated capsules I linked to above ...
Here's a screen shot of the mix set up....
    236.6 KB
Must have taken a long time to get it all done digitally. Seriously, great job. I'll take a look at your mic project there, it sounds really good.
Nope, TSC-1 and 2 are produced by Takstar. Exceprional consistency, not just another generic capsule. Here are some of my measurements of these. Jules has clearly some kind of business agreement with Transound, so i gues ndaa. But these are 100% produced by Takstar. They are also found in Akg Perception mics.
Click on following posts and you get to see the measurements.
This Takstar capsule and CY002 have pretty much identical response. Takstar is about 1db less bright. They can really be used interchangeably. Green-Takstar.
And this is Takstar capsule with applied measured vintage u87 circuit curve, and Bob's your uncle.... Exact u87 response.
However there's a catch! These measurements are without mic body/grille. The challenge is to make/obtain a body/grille that performs as the original to maintain this response. Not an easy task i promise!
This is the upper Takstar curve (green) w 1/12 smoothing against real Neumann U87ai response (red). Please disregard the difference in low end it is due to proximity effect i used an omni reference mic for U87ai measurement, low end is otherwise identical. The difference above 13k is mainly because of u87 grille, it reduces some of the hf.
Great to know. So I should get in contact with Trakstar. Any idea what the price might be to send just one or two? Thanks for the detailed answer. I’ll look into those posts.
Inexpensive capsules ...
I have had good luck with several low cost capsules purchased from Chinese vendors on eBay for $25 to $35 including shipping. They provide comparable performance to the TSC-1 capsule I purchased from JLI Electronics. JLI has provided exceptional communication and service over several transactions, so I pretty much decided to stick with them. Your mileage may vary. Good luck. James
I just received one of these. Onesided. Nice capsule, i ordered some more.
https://a.aliexpress.com/_mOlwK3w
That's the edge terminated capsule I have been referring to.
As you say, a nice capsule......especially for the price.
Anyone have a link to a double sided version? I can never tell with what's what with AliExpress capsules. Also have you measured this one? Or is it the same as most edge terminated ones from on there?
