k brown
Same as CM-60, not '63.Are you sure the Avantone CK-1 is the same mic as the CM-63? Comparing the switch locations and tapered tail, it looks more like an Alctron T02A to me, which is most likely nothing else but a Shuai Yin SYC90S. Alibaba link below. They have 22mm bodies, which fit the 3U capsules.
https://x.alibaba.com/Ax2Znj?ck=pdp
Jan
Avantone has an added pad switch, so boards are different (actual circuit similarity, I don't know; they do mention styrene caps, which the Takstars don't have), but bodies and capsules the same.
Perhaps more accurate to say the Avantones are built on the Takstar 'platform'?
