motordisco
Active member
- Joined
- Mar 30, 2009
- Messages
- 27
Hi, does anyone have experience with this model?
Beyer bv/tr 310 003 002
its a 200ohm input, 2kohm output, turns ratio 1:3, freq resp 30-15000Hz
I read about it slightly, spec in beyer catalog.
Would just like some spontanious input on possible use, and experience.
So that I can decide wether to spend time in designing a bunch of projects based on this, or not.
Can it be used then as a mic prea input trafo? as DI trafo backwards?
..and even inside a actual diy microphone design? ( later project perhaps )
Thanks and best greetings
