OfficialCodini
New member
- Joined
- Apr 22, 2021
- Messages
- 4
I’m looking to build a passive balanced line level attenuator with a TRS jack to connect any universal expression pedal, and a single knob on the unit to set a minimum volume level. I know practically nothing about circuits, but it seems simple enough that I could build this for fairly cheap if I knew how. I’m looking to connect it with some XLRs so it can sit within my rack chain, and I can shift the volume from far away on the expression pedal to anywhere from -6db to 0db or -infinity to 0db depending on where the minimum volume knob on the unit is set. Is there an easy way to accomplish this? Thanks in advance!
