The last time I built a tube power amp was back in the 60s. For quite some time I have been meaning to build a small tube power amp for listening to background music in my workshop and listening to my mic pre and EQ designs. I came up with a simple single ended design using the EL84 and added a first stage using an ECC88 with dc NFB similar to the EZTube Eurochannel design.
I had an old guitar amp chassis to build it on and acquired a couple of suitable output transformers. For the supply I had an suitable mains transformer left over from some early experiments. I used the HT250 board fitted with 500V capacitors and 5W resistors to cope with the expected total current. First I just built the output stage, powered it up and verified the current draw from each tube was OK. I had a pair of Tannoy book shelf speakers connected to it and there was a fair bit of hum audible. A lot of this is undoubtedly induced by the mains transformer straight into the output transformers. I have ordered a small toroid replacement which I hope will fix this.
Being impatient, I decided to hook a 10K:10K transformer direct to the EL84 grid to see if I could get any sound. Wired the transformer input to a TRS socket and plugged it into the output of my Focusrite USB thingy. To my surprise there was plenty of output level. So I quickly wired up the other channel and soon was listening in stereo.I will change the mains transformer when the toroid comes but right now I am not sure if I will bother to include the ECC88. Thta must be the simplest stereo power amp ever, just 2 x EL84. When I have got rid of the hum I will definitely make some distortion, frequency response and noise measurements and then decide if I need to include the ECC88 stage. I'll post some pics later.
