Neumann U67 Clone : D-U67 Tube Microphone Build Thread.
There are some mentions in this thread about bridging pin1 from the 3-pin XLR and pin3 from the 7-pin XLR. I have not done this as for now, would this get rid of the hiss?
That's more likely to affect low-frequency hum or buzz (dealing with 50/60Hz mains interference and/or harmonics thereof), rather than hiss.
Hiss usually points to higher-frequency noise, more often originating in leakage-causing/conducting subtances in the high-impedance areas of the circuit. Which is not unexpected (perhaps even likely) in this dog's breakfast of a physical design 🙈
Easiest thing first - try some other tube(s). If the noise stays the same, that points to the thing(s) that stay the same, ie. the circuit and/or construction.
So i put in a different tube. Still same story. very low output and very thin sounding.
I am pretty sure that the circuit is alright. Are there any other measurements beside H and B that could bring me further?
I finally got mine working and it sounds amazing with the BeesKneez capsule! Any one have any advice on what Caps I can change to mess with bass response and de emphasis? want to try some different things for more or less high end and bass.
Any one have any advice on what Caps I can change to mess with bass response ?
You can remove the connection in S2, just open S2 and you will have more bass and more bass extension, you will also have more bass in proximity effect, so it's something to consider.
I prefer to have mine with S2 open, and use Pop-shields and distance when I feel that too much bass is a problem.
S2 it's a low cut inside the circuit, leaving it close or open it's an user's decision
Any one have any advice on what Caps I can change to mess with de emphasis? want to try some different things for more or less high end
Some people remove C17 for less Hi-Freq attenuation, but the overall circuit is not that simple, and the De-Emphasis network is a bit complicate, personally I would not mess around with it.
This has been discussed a lot in this forum in the past, you should read this:
https://groupdiy.com/threads/u67-de-emphasis-network.68495/
S2 it's a low cut inside the circuit, leaving it close or open it's an user decision
Thank you I’ll give it a read
Any Advice on how to get rid of 120hz hum? its about 15db above the noise floor. i can also see maybe 10 db above noise floor in everything 60hz and below. I tried grounding the case lid to the chassis and it made no difference. could it be filter caps?
