In my continuing search for solutions to the Baxandall quandary, ( http://groupdiy.com/index.php?topic=56238.0 ) I re-examined the UA610. Its switched EQ is principally in the NFB loop of the output amplifier. It occurred to me it might be possible to do something similar around the NFB of the output amp of the EZTubeMixer channel amp. It turns out that the basic NFB topologies are identical. Only component values are different. I did a few simple sims and it seems to work. I notced that the original +- 6dB EQ range has been extended in the ne UA2-610 to +- 9dB and both bass and treble ranges have three selectable frequencies. This complicates things a bit but I think it should be feasible. If there is some interest I will take it further.
