Sun King
- Joined
- Aug 17, 2013
- Messages
- 46
Whoops said:.........Sun King said:Could it just be that without the grounding to PIN 1 of the XLR that it's not working with a condenser mic?
All Pin 1 XLR inputs should connect to chassis
Chassis should connect to Earth Pin on Power prong
0V on PSU should connect to 10r (2watt) resistor in parallel with 0.1uf (63v) cap and then to Chassis
0V of each Mic Pre PCB separately should connect to 0V on PSU
Can I check what exactly is the 0V connection? Am I right in thinking that it's the ground connections on the preamp PCBs and PSU PCB?
Also, would a 10R - 3 Watt resistor be ok? That's what I can get locally.
