Faceplate hole for VU meter??
Matt C
Saint Paul, MN, USA
How do folks usually go about making a large hole in a 19" chassis faceplate for a big VU meter? Is it possible to get a punch that big? Am I better off just ordering a custom-machined faceplate? any advice is much appreciated.
In aluminium, I use a simple handheld wood-router running in an attached 4mm acrylic jig with an appropriate cutout
+1
I do this similarly for all my larger cutouts, aluminum is just shiny wood. 😅 It's not for the faint-hearted, wear protective gear.
I make round cut-outs with a special (circle) jig for the edge router and templates for square cut-outs with thin LEGO bricks, no joke.😎
Edit: That's how I started (on my washing machine), I've optimized the process a bit since then.
' https://groupdiy.com/threads/diy-pr...mps-buffers-or-microphones.84324/post-1098005
Remember that the VU meter you are fitting must be designed for the panel material as STEEL panels mess up the balistics of moving coil meter movements. Aluminium is not a problem.
I’m surprised I haven’t tried that, as what @rock soderstrom said, it’s just shiny wood. I’ve used my table saw with 80-tooth finish blade to make straight cuts on sheet aluminum, and miter saw for angle, round, and square tube many times with great results.
