I have a Fairchild 661 gate which I intend to convert into a 663 compressor with buffered I/O, balanced inputs, etc.
But first things first: I want to make this 661 work "as it".
(This is linked to the thread: Fairchild 661tl Gate... convert to Compressor? but I prefer to create a dedicated thread for this debug issue)
Here is the original schematic:
All the capacitors were originals (and very dead) and the light bulb too.
Thus, I replaced all of them and the light bulb with a LED.
I did also convert the board to a 8V DC supply by removing the diode rectifier, C5, C6, C7, R9 and R10.
So here is the current schematic:
Now it appears that the LED is always "on", whatever the input signal.
Since all capacitors were replaced, I suspect a dead transistor.
My input test signal is (I turn it on and off to eventually "see" the gate effect, and thus the LED turn off):
At the Q1 base, with threshold set to minimum I have:
-> The amplitude of the input signal looks very small to me to be usable afterwards, ok we're just after the transformer but...
At the Q2 base, with threshold set to minimum I have:
-> Without any surprise, the test signal is now almost lost, thus if I turn it off I have almost the same output
At the Q3 base, with threshold set to minimum I have:
At the Q5 base, with threshold set to minimum I have:
And the same for Q6, thus the LED is always on, whatever the input signal is.
Does someone has any idea of what might be wrong ?
Thanks a lot for any advice!
Edit: updated the modified schematic (with DC supply), VCC and GND were inverted
