[quote author="uk03878"]I guessed it was the Strawberry one...[/quote]
Don't know about that...
About 15 years ago, a manager of a local band had a front panel of an AMS RMX-16 which was 'faked' to look like it was operational. -It had been mocked up for 'set dressing' on a short-lived (and utterly crap) TV programme called -imaginitively enough- "studio"... from the early 1980's.
At the time I considered buying it as a rack blank, but I had enough Funk Logic type stuff to last a lifetime, so I didn't buy it.
That one was custom made by AMS. These all look to be genuine product also.
When I did the value calculations in my head, I figured that I'd go up to £250 for this one. -Later on when Marty posted about not letting it get up too far, I was a bit troubled, but I guessed (rightly as it turns out) that he probaly didn't have the same mental value ascribed to it, but I reckoned that someone else probably would... so if I
didn't bid, then
NEITHER of us would end up getting it.
I decided against posting or even PM-ing Marty to discuss high bids, and took a look at what Marty's first high bid had been (£75), when the bidding started to climb. -That sealed it, I thought... that and someone else seemed to keep bidding and not have a planned 'upper limit'.
In the end it seems to have worked out. Marty, Abby and others may well end up having access to good LA-2a cases which I'm going to look into having manufactured, using measurements taken from this one...
Then once it's been analysed, I have all the rest of the important genuine bits: the correct Magnetika transformers, (as used in the reissue are seen in
this photo, mounted to 'bloo' adaptor plates) a genuine Teletronix T4B, all the turret boards and a Power Transformer. Everything else is non-specific and easily obtainable.
Keith
