I made an isolation box and use a 240 volts fan like this one below connected to a dimmer so I can adjust the fan speed incase I want it to be quiet when I am recording:
I have just found out that the fan triggers the circuit breaker in the house every now and then. I am a little confused as to why it happens when the fan only uses 19 watts of power and also it varies how it triggers the circuit breaker.
eg.
- All my equipment could be on and running ok for a few hours, then all of a sudden it would trip the circuit breaker or;
- I turn my equipment on, one by one, then when it gets to the fan, the circuit breaker would trip
I know its the fan that is triggering it because when I hook up the fan to a different line of the house, the problem goes away. I do not want to use a different line, because I have to use a long extension lead that would run across the studio and house and can make people trip.
Is there a way to keep the fan in the same line, maybe make some form of simple mod? I am thinking maybe its when I turn it on and that start up of the fan is causing the problem or maybe the way I have used the fan using a dimmer causes the line to act up?
I am considering switching the fan to a 12 volt fan and use a 12 volt power adaptor, because using a power adaptor on the same line doesnt seem to cause issues but I am concerned that I will loose my fan speed ability.
Does anyone know if the dimmer you use for lights, can be used in a 12 volt system than 240 volts?
eg.
