Need help with a switch for a studio ventilation fan
DFischer
USA
I have a modest size control room in my home studio that requires constant air exchange when in use. I'm currently switching the outlet feeding the fan with a standard timer designed for a bathroom fan. The timer's not really working out, because I often overstay the amount of time I programed in, or I'll forget to even turn on the fan in the first place. If I had to do it over, I'd wire the fan to the light switch, so that the fan would be on constantly when I was in there. Re-wiring at this point would be destructive and messy, so I thought about using a light sensor to turn on the fan in place of the time. Lights on = fan on. However, I can't seem to find any simple photocell sensors mountable in a switch box explicitly rated for fan use. There are plenty of motion sensors rated for fans, but not a lot of motion is happening while mixing.
Leviton gives these specs for motion sensor switches:
Am I right to think that the same ratios for resistive/inductive/capacitive loads would hold true for photocell switches? In other words, if I buy a photocell rated for 600W with a resistive tungsten load it would also handle a 1/2HP (372W) inductive motor load as well? Am I missing some other detail?
My current fan only draws 38W:
Fan
I'm looking at this switch replacement:
600W Switch
I see the obvious flaw with original my question. Lights on and the fan goes off. I suppose I can use a relay to reverse states though. Any other suggestions?
The forgetting problem could be addressed by a post-it or noticed on the dask / chair / mixer etc 🤔
In a perfect world without me in it, then yes! :)
I actually found a marketing video from Intermatic where they show the mechanical relay they use inside their switch. It's an Omron G2RL-14-E, which should be able to handle my motor load. I just need to crack open the case and switch to relay to NC or re-wire the connections to the existing relay. That was nice of Intermatic to show the inside of their product.
Unfortunately my control room is split in two zones with the wiring. The front is on a 20A circuit designed to run all audio devices. The back is on a separate 15A circuit on a different phase than the audio circuit for running the lights and fan.
The room is built with 2 layers of 5/8" drywall hung on RC channel on the inside, with 2 layers of 5/8" on the outside, all smeared with green glue. All the outlet boxes are covered in acoustic putty. I'll definitely live with the nuisance of the switch before I start cutting drywall or trying to fish wires through the rockwool. :)
