Rompstomp89
Hey all,
Im working on a protype of an am864 limiter circuit and im a having a bit hastle trying to get my meter to work with this circuit.
I know the meter works I was able to get some gain reduction movement by applying an 470K resistor in the place of R2. Now that might sound crazy but its true. The original R2 only requires a value of 240R....Something isnt right here. With the 470K in there I get very bad motorboating and some signal loss. Not good. I measured with an ohm meter across the meter and got 150K. Is this meter just way too out of spec for this project? I read somewhere on here that most VUs have an internal resistance of 3.9k. do i need to strap a resistor on the back of the meter to bring it down? do i need diodes in there as well. I have used another meter to test the circuit and had to drop a 1k in place of R2 with slight motorboating when threshold is cranked. That meter however is taken up by another project. I appologize because im a noob when it comes to this sorta thing. All voltages are correct when R2 is to spec. Would love to hear some insight on this delema!
Thank you in advance for help!
heres a link to the schematic I used.
https://www.google.com/search?q=am864+schematic&es_sm=91&tbm=isch&imgil=3MzLMElhdSEqvM%253A%253BAJ5goD9fCodU5M%253Bhttp%25253A%25252F%25252Fwww.preservationsound.com%25252F%25253Fp%2525253D7921&source=iu&pf=m&fir=3MzLMElhdSEqvM%253A%252CAJ5goD9fCodU5M%252C_&biw=1920&bih=915&usg=___n3P7-YRO1_HP3TlD6pKWtjmKYE%3D&ved=0CDYQyjdqFQoTCKvfp93xv8cCFUGegAod52EJ8w&ei=MRjaVeuCIcG8ggTnw6WYDw#imgrc=3MzLMElhdSEqvM%3A&usg=___n3P7-YRO1_HP3TlD6pKWtjmKYE%3D
