Slenderchap
pietro_moog said:- i need to fix the input trafo to the board. how do you do that....
- i've seen the rotary switches are a few mms from the border. so they are not designed to sustain the pcb........
The input transformer fitting procedure is in the colourbook:
http://www.audiomaintenance.com/downloads/ez1073_colourbook.pdf
The rotary switches are not intended to support a PCB.... the PCB should be supported by standoffs on the base of the metal box.
Colin
