spneca
Member
stribor1 said:Hi there, I'm by no means an expert but I can share my experience after two successful builds, since I had similar issues.spneca said:Hello all,
I just finished a build, and the line input and eq works great. I checked the power voltages and adjusted the output bias and everything was fine. My problem is that the Mic Pre section is not passing any signal. I did some probing and found that there is continuity between pins 2 and 3 of the mic in. Looking around the board , I could not find any obvious short. I did some trace cutting and the short does not appear to be near the connectors. One thing I noticed is that all of the contacts of SW4 (the impedance switch) have continuity. Could it be that I have a bad switch? Could this be the cause?
Continuity on the mic input between pins 2 and 3 is normal as these pins are connected through the mic input transformer which has a low DC resistance. I have the same on my two builds and everything is working fine. One hint if you are using a dynamic mic, make sure the phantom power is not on. The 48V switch pointing downwards is the phantom power on position, so if you are using a dynamic mic it should be pointing upwards otherwise it wont pass any signal. The labeling on the frontplates (from both Dan's) are a little bit confusing regarding this, and there is no led indicator for the 48V on/off position.
J.
Thanks for the reply. Unfortunately, this did not solve the problem. I used an SM57 to test, and I got the same result with the phantom power switch in both positions. If I hit the top of the mic I can hear a very quiet impact sound, but the gain doesn't seem to affect it at all. I tried the mic and cable on another pre to verify that they are working, and they both checked out fine.
