You pretty much summed up the recurrent problems of this otherwise rather good series of amps, although there are rants about each new version being less good than the previous.CJ said:we hard wired an Alpha larger diameter pot in there, the Fender frame pots leave much to be desired, vol pot is most used, so why not put a better one in there,
also hard wired some Switchcraft 12B jacks instead of the old pc mount plastic stuff, and we bypassed the pwr amp in jack,
360 ohm 5 watt zener resistors are cooking the board, good thing we changed them to 390 7 watt, as they got so hot that the solder was loosened up, that was probably the other noise, vibration while playing cause the joint to freak out the mix,
Does it ? Seems to me like the end bells block any airflow...CJ said:the shim lets a little air flow through there,
What do you mean "change"? Change the value or brand, or something else? What can be expected by "changing" caps?Gus said:If you want to try a cap experiment change the first two caps in the PS (plate and screen)
If you have a cap checker measure all the parameters you can of the caps and note what happens
