Compact desktop line mixer?
Yes, they are directly on opposite sides of the board. I didn’t go so far as to check if the footprints overlap (yet). They might need to be offset. The layout was all preliminary - like I said before, just a POC. I have done this with other project before, and while it is a pain, it can be done…as long as you solder the correct side first!
These are the rotary switches I spec’d. I used them once before and they seemed fine: https://www.mouser.com/ProductDetail/Alpha-Taiwan/SR10010F-0204-20F0B-C7-N-0027?qs=8%2Br4Hz5Xir/fy%2Bqxa0GVpg==
[ALPHA -- SR10010F-0204-20F0B-C7-N-0027] -- See below:
>> Have you determined what your PCB-outline dimensions are yet? If so, can you let me know what they are??? THANKS!!!.....
[These are the rotary switches I spec’d] -- Here's a really spiffy idea!!! How about providing a list of all of the LED's, potentiometers, switches and other electro-mechanical components' Part Numbers that go through your FPD-panel? I've got an idea!!!.....
One interesting aspect of Schaeffer's front panel service is that they can use customer provided material so, rather than buy a complete enclosure like the Takachi and have to replace some of its panels with custom ones you can send the blank panels to Schaeffer for them to use on your design.
[One interesting aspect of Schaeffer's front panel service is that they can use customer provided material] -- So.....you're saying that if you send SCHAEFFER your own panels, they will then punch them out to your own specifications??? I've never heard of or have known of any sheet-metal shop ever willing to do something like that. That's a really interesting piece of information to know.
However, I suppose "the catch" is.....is that with you supplying the material, you also end up paying for the shipping cost twice!!!
Absolutely!
I thought I had found every small rotary switch known to mankind but that is a new one for me. Very interesting.
