Fender Twin-Silverface
CJ
California
this time we have a worked over silverface,  Svetlana 6L6GC, Hammond replacement transformer, has a distorted sound,
    198.2 KB
gonna rewind this xfmr to get higher load for plates, see if that helps,
supposed to be a drop in replacement,  can't vouch for that,
http://angela.com/hammondoutputtransformer1750w.aspx
    140.5 KB
more chassis, pwr side,
cable wrap is just a piece of wire, soldered to ground, ham radio trick?
    199.1 KB
OPT, not a bad job, layered paper, like the original, 7 section coil,
125 EI,  1.5" stack
    125.4 KB
pri wire is pretty thick, only 36 ohms for the whole pri, do not know if this is the original wire size, DCR seems low,
structure- P-S-P-S-P-S-P
turns pri - 515 + 515 = 1030  sec  46 turns - 3 sections in parallel  22:1 ratio
2K:4 ohms
    166.6 KB
RCA 35604 diodes,
pwr trans - L022756
choke - 022699
reverb xfmr - 022921
    129.8 KB
