Do you have tube retainers on the sockets?
Matching isn't important unless you are running quads, the output transformer will take care of mismatch on a pair.
For quads I usually put like say two number 8's on one side and say two number 10's on the other side. Set the bias to split the difference.
Not so good to run an 8 and a 10 on one end of the xfmr as the 10 will hog current and age faster, or bias will run away and you will have a meltdown.
I can see agonizing over tube matching and microphonics for audiophile amps but a guitar amp? You have to be joking. At least in this town where every amp I service comes in with every knob dimed. I can't even go to a show anymore because I serviced every amp within a 100 mile radius and I don't want to worry about an amp blowing up while I am there as they will want me to fix it on the spot with duct tape and a coat hanger.
One guy kept bringing his Carvin back. So I went to a show to see why. So what he does is get completely whacked on drugs and alcohol, sets the amp on 11 with stomp box and just let's the amp feed back at 500 kc for ten minutes. After I saw that I built him a p to p jtm 45 on the carvin chassis and he has not been back sense.
VTV drops a weight from a fixed height to quantify microphonics.
If you gig on a regular basis you will replace tubes once a year so just let it go and hope for less noise on he next batch.
I swear the best amps have heard have microphonic preamp tubes and mismatched phase inverter tubes. I think I have done about 1500 amps in the last 10 years.
And remember, once you get past 20 watts on a pair of 6l6 or el 34, where you set the bias makes absolutely no difference in sound as you are swinging the grids well past the point of caring. Now if you like light jazz, warm that bias up a bit.
My favorite amp is a Princeton reverb with bugle boy 60's Holland el84's into a Fisher output into an Allesendro 10 inch.
Old rca and ge sound so magical and last so long compared to today's junk that any extra noise is worth it. Especially with the war in Ukraine making the price of new tubes ridiculous.
Oh, and one more thing before I get off my soapbox: long tail phase inverters suck donkey.
