tgs
- Joined
- May 30, 2013
- Messages
- 84
I have an old Fender Yale Reverb that I don't really use for anything so I figured I'd play around with some mods. I wanted first of all to try to get it to distort a bit more. If I dime the volume and gain knob I get a pretty good starting point, but I want to push it a bit more. I found schematics here:
https://dokumen.tips/documents/fender-yale-reverb-schematic.html?page=1
I figured at first that I'd do something around R23 (after the gain pot so I tried adding diode clipping in parallel with R23. It did nothing other than possibly dropping the level a bit.
So next I looked at the diode clipping stage D3-D4. I figured I'd put a resistor in parallel with R9 to increase the feedback voltage. Did the opposite of what I though, brings the distortion down. So I guess I'm getting it all backwards.
I'll be very clear here that I'm a total novice and I'm just experimenting a bit to try to learn. So what I'm looking for is mostly to get some ideas for starting points for experimentation. The circuit looks a bit strange to me, I'd expect to find the diodes around the gain pot so I guess there are some basics here that I'm missing. Anyway, if anyone has any tips on this I can try out, I'm all ears. Thanks for your attention!
