samgraysound
Hi all,
I'm trying to fix a Filtek MK3a EQ module. The low frequency adjustment has no effect on the signal whatsoever. It passes signal fine and all the other bands are working normally.
The schematics I've been able to find don't seem to match up to what I'm seeing inside the chassis, none of the resistor values seem right, there's a ton of 330ks connected to op amp pins and not single one of the schematics, the caps don't seem to be where the schematic shows them in the circuit either.
Some caps have been replaced but there's still a few original electrylytics on (what I think) is the lo eq section. I'd like to replace them but I don't understand the codes printed on them, and due to the schematics stuff I'm not sure of there value. The codes are: 39, F63, K5, K6
Plus everything is in German.
Have you worked on the internals of these?
Do you have any suggestions on how to proceed?
Do you have any leads or thoughts on the schematics?
Do you recognize the Capacitor codes?
Attached are schematics I have plus a pictures of the caps
