bluezplaya
Here is my latest build. It has been a long time coming and it is finally finished! :green: The Neve 1272 Hot Rod’s with Marinair 31267’s and JLM 1:1:1 output transformers. The stuffing of the boards was fairly quick and wasn’t too much of a headache. I just had to piece things together as they came in the mail. I first got the 283 cards and started building a BOM. Once the parts were in from Mouser, I stuffed the cards. I won the 2n3055’s on an Ebay auction and waited for those to arrive. I found a spare pair of the hot rod boards from Peter C (thank you, sir! :thumb: ) and had to wait 3 weeks or so for them to arrive from Johannesburg. I then ordered the output transformers and Go Between’s from Joe at JLM (and waited a week or so). Surprisingly, I found the Marinairs on Ebay just minutes after they went up for auction…it was meant to be.
I ordered the case from Circuit Specialists, which is a Yahoo web store. I won’t order from them again :? . The product looks fine and works fine but I’m used to Par Metal and their steel is heavy duty compared to these cases. They’re a bit flimsy. The front panel and bottom I drilled myself with an 18v cordless drill. For the back panel I had to visit the ole’ man; he’s got a nice stand up drill press and I needed a 7/8” bit for the XLR. The front panel is painted with good ole’ Ace Hardware spray enamel.
The layout I designed in Front Panel Designer and just printed out as a template to center punch the holes. I would like to order another front panel from them but for right now this is fine. I just need to label everything neatly. Anyone have any suggestions for labeling?
I would have to say that this is probably my best build because it gets better with practice. I took more time with this than any others I have built and am glad of the results. I went the extra mile with wiring and also the placement of the boards and trannies. I left the other side open for adding two more pre’s in the future.
The biggest bitch about this was troubleshooting the grounding :shock: . Everyone seems to have a method for grounding Neve and so I just tried to take a little bit from everyone’s perspective. At first, I was getting some fair signal, and so the day after I finished the build I tracked a snare drum on a session for a friend but it had kind of a grainy sound. I brought it home and started fooling with it and had no signal, then the resistors on the Hot Rod boards and the also the PSU were smoking. Problem after problem….
To make a long story even longer, I found that the output transformers being connected to the TRS ground (pin 1) was somehow shorting and torching the 10R on the PSU :shock: . I reworked the output grounding. I also found a suggestion on a thread from the Geoff Tanner site about the 31267 wiring. So I wired primary as 8 and 10, and secondary as 3 and 5.
So now that my Neve cherry has been popped, I’ll be tracking vocals for my friend tomorrow. I hope to God they don’t ask me to build them a couple of channels.
Many thanks to anyone who helped me on some questions and also to those who designed, fabbed, sold to me, etc….Joe Malone, Greg, Fabio, Peter C., Guavatone, Madriaanse, etc. :green: :guinness: :guinness: :guinness:
Peace, Adam
