DrFrankencopter
Hi Gang,
It's been a few years since I've been here. Lots of activity I see! I'm trying to get a few DIY projects that I started a few years back off my plate. 1st up is the Purple Audio MC76.
The schematic is here: http://www.purpleaudio.com/pdflib/PurpleMC77v34.pdf on page 13
I bought the kit way back when it was still the MC76 board (not the MC77). I've got all the PCB components (I think), & transformers but need some help sourcing the pots. The schematic calls for:
Output pot: 250K 2W Audio taper (I suspect these will be pretty common...as it's a typical guitar part value)
Attack: 25K 1/2W no taper specified, but I imagine it's linear. The original had a switch output at the end of the travel to turn limiting on or off (not quite bypass, as the audio sill goes thru the audio path and Xfmrs)
Release: 5M 1/2W no taper specified (I assume linear)
Meter zero adj: 2K (linear?)
Any part #'s (digikey?) would be helpful.
Also, I see in the meter driver section of the schematic (lower left corner) there is a resistor R44 specified as T&C with a value of ~1K...I guess this means 'try and see'? The same nomenclature appears on the ratio switch for a resistor going between R19 and the common to all the switches. Any guidance here would be great...
Finally, on the schematic there are 3 LED's in series leading from the +30V to Q22...what are these, and where do they go?
Kris
Kris
