i don't want to rain on anyone's parade here - as some of you know, i'm a big fan of the ol' digits 'n transmitting them here and there.
There's one big stopper with this device. I think it's the same for the bridgeco solution, as well as the TI solution (those are the 3 players I can think of...)
BGA packages. For those of you who don't know what BGA is... it stands for Ball Grid Array. Rather than having nice little legs coming off the chip, you have small balls of solder.
The idea behind it is that you can get more control on things like capacitance etc + fit more pins per package. The difficulty comes with developing boards for them.
They can't be hand soldered. you can't actually see the pins to solder them! I've heard some people can do it in an oven, but then, there's a strict temperature profile that must be followed.
Once you've got that far, if your board doesn't work, you may have to do things like XRAY to work out which pins didn't solder etc.
Oh, and don't forget, like most high speed processors (the chip contains a processor) you'll most likely need at least 4 layers - 2 for signal, 2 for power.
So, assuming we've got the chip on the board we've designed, (woohoo!) - most of the time, there's more to the chip than just plugging in I2S streams and expecting it to work. There's usually a bit of programming that sits around it. Whilst we probably have the resource here to do it - uploading the code, or burning flash devices to contain the code doesn't really fill me with confidence.
I don't want to crap on your idea though. I'm sure there have been many discussions in this forum which follow your idea (I started one or two mself).
Personally, taking experience from some of teh customers that I talk to on this topic - the solutions to the DIY'er are becoming more and more clear.
Leave the PC interface to the high-quantity, windows/mac driver writing soundcard guys, and hack into it with our own mic/ADC/DAC Frontends.
So far, the most obvious way I've seen of doing this is with ADAT optical. Although, the only problem there is that you're then limited to 96KHz (4 channel ADAT).
BTW - TC is involved with the new wavefront chip. My understanding is that TC Technologies Canada designed the chip. Wavefront are acting as the distributors for the chip.
Ah... It feels good to be posting again.
Toodle Pip.
R
