darkus
I recently bought a used Toft Atb24, serial number 000536.
Anyways the console has some issues and I am installing the meterbridge soon so I might as well fix the issues, but I would need some help as Im not familiar with this console. So the issues are:
1. The -20dB led on channel 5 is lit all the time even if nothing is plugged in or sent to any of the inputs jacks (xlr, mon, or line in) even if input gain and channel fader are all the way down.
2. Channel 11 leaks to LR mix regardless of the fader or the position of the LR switch. The channel works like it should with all other busses and pan,solo and mute work also.
3. Channel 3 has a similar issue than channel 11 but the fader has slight effect on the volume. (around 3dB) Signal leaks to LR even if the LR switch is up.
4. Mic input 20 is dead.
The previous owner had swapped channels 11 and 12 and the problem with the channel 11 didnt get fixed, so we know its not the channel card that has the issue. He also recapped some channels which he said were moved to the end of the channel count (23&24).
If you have any ideas what might be wrong, and what should I take a look at, then please, help is needed!
Im thinking if I should replace the pushbuttons on channel 3&11, does anyone know what switch fits to this console?
