Good Morning Microphone Mavens !
Looking for what to call, and how to obtain, a small quantity of what I believe is called open cell, low density, foam. You know - the type that is used inside and outside microphone head shells and inside the Shure Super55 and to pack glassware and other fragile items. It is sorta like the foam they use for soft, low cost acoustic wall squares ... but much thinner. Searching eBay, AliExpress, and other sources typically leads to hundreds of listings for thicker, denser, EVA foam sheets (like what craft stores sell) or much too thick, medium density upholstery foam. I guess a useful form factor would be 25mm x 25mm x 2to5mm sheets or strips, rolls, etc. Of course, I only need a small quantity, which likely makes it more difficult to obtain.
Any ideas? Thanks! James
